MathScript Node Outputs Cluster of Arrays Instead of a Cluster of Elements
Updated May 3, 2018
  • LabVIEW MathScript Module
I need an array of clusters, each cluster containing two numbers, as input for my function. This array of clusters shall be be provided by a MathScript node. My problem is that the node's output is actually an array of clusters where each cluster contains two arrays of numbers instead of two numbers. How can I change this?
Use an indexing For Loop and array manipulation to extract the first element of each array and then pack them into a new cluster:
The reason behind this behavior is a difference in cluster handling in MathScript and LabVIEW. Element inside a struct/cluster inside an array are always treated as an array itself, see the following example.
This creates the struct/cluster out with two elements, x and y:
After adding this line of code, out get automatically converted. It is not a cluster of elements anymore. Now it is a cluster of two 1D arrays:
The same cluster of two 1D arrays can be created by this code:
