The vertical range for both channels can be configured with multiple instances of the niScope Configure Vertical VI or by using property nodes. Each instance of the configuration VI has a required input,
Active Channel, that designates which channel to apply the property to. Figure 1 shows the vertical range of Channel 0 configured as 1 V
pk-pk, followed by the vertical range of Channel 1 configured as 10 V
pk-pk.
Figure 1. niScope Configure Vertical VIThe same effect can be achieved by using property nodes, as seen in Figure 2. This method is more compact, as both channels can be configured with one property node.
Figure 2: niScope Property Nodes
