Make sure that you have
optimized the throughput of your deviceIf that has already been done, the sample rate might have to be reduced. For example, if you are only able to transmit at 10 MB/s, and you acquire 12 channels from three NI-9222 C series modules at 500 kS/s/chan. The throughput of these channels combined is 12MB/s (based on int16), so you will likely receive this error.
If you change these to 400kS/s/chan, then the throughput would be 9.6MB/s which in this case would work.
