Error 1003 in libpropPage_5Friends.vi When Accessing Class Properties in LabVIEW OOP Project
Updated May 3, 2018
I'm working to improve my class structure in LabVIEW OOP but after a few changes I can no longer access my class properties in my project and get error 1003 at libpropPage_5Friends.vi? What do I do to fix this?
You can locate this libpropPage_5Friends.vi at the directory below. This location will depend on your version and bitness of LabVIEW (This example uses LabVIEW 2017 32-bit):
C:\Program Files (x86)\National Instruments\LabVIEW 2017\resource\Framework\Providers\VILibrary
Open up the libpropPage_5Friends.vi and press the broken run arrow to see what errors exist.
If the VI is unable to locate specific files and dependencies, Browse for them and re-link them to the VI having the problems. After these paths have been re-linked, go back to your project and right click your Class >> Properties. The issue should no longer persist.
