When Changing Counter Timing While My Program Runs It No Longer Triggers Other Tasks
Updated Dec 26, 2018
  • USB-6363
I have a counter task that I am using to trigger other tasks. When I change the high and low times of the task I am using to trigger while the program is running it no longer triggers the other tasks.
There may be something wrong with the way the counter task is being changed while the program is running. Try adapting your program to change the timing using the Change Counter Output Frequency on the Fly example to correctly make these changes.
