Match Pattern Returns Wrong Index
Updated May 3, 2018
When using the Match Pattern VI with "123456.78" as input string searching for ".", the offset past match output returns 1 (and not 7).
The Search and Replace Pattern.vi, the Match Regular Expression node, and the Match Pattern node interpret the pattern wired to them as a Regular Expression (also regex or regexp). The period is a special character in regex matching and needs to be escaped to be interpreted as a period. Use "\." instead of ".".
Regular Expressions
A Regular Expression is a sequence of characters that can define more specific searches compared to simple string comparisons.
Examples:
  • "\.[a-z]" matches any full stop followed by any lower-case letter between a and z.
  • "(?<=\.) {2,}(?=[A-Z])": At least two spaces are matched, but only if they occur directly after a period (.) and before an upper case letter.
Search and Replace String node
The Search and Replace String node can use both a regex and a normal string search: Right-click it to toggle between them. Notice the small asterisk (*) appearing on the node's icon when it is set to Regular Expression mode:
