LabVIEW Database Connectivity Toolkit is only compatible with the 32-bit version of LabVIEW Base, Full, or Professional Development System for versions before LabVIEW 2019. If you are using a 64 bit version, you can download the 32-bit version from the NI LabVIEW Downloads page. Note: The NI LabVIEW Database Connectivity Toolkit was released for 64-bit with LabVIEW 2019.
If you have a compatible version of LabVIEW and are still seeing this error, follow the steps below:
- Make sure your toolkit is properly activated. Follow the Activating NI Software help article to activate the toolkit in NI License Manager.
 - If activating the toolkit does not resolve the issue, try to force reinstall the toolkit. Follow the Force Reinstall Non-Working or Corrupt NI Software article to force reinstall the Database Connectivity Toolkit.
