TestStand SQL Database Call Not Recorded into Variables
Updated Mar 26, 2018
  • TestStand
My test parameters are stored in an SQL table and my sequence file is intended to get initialization information from the test operator. Once the item number is entered I need to query the SQL table and return the corresponding record. My database connection is working and as far as I can tell my query is being executed. However, it seems to be returning 0 records even though I know the record exists in the table.
  • Ensure that you are following the proper procedure when making a SQL Call in TestStand using the Database Step Types.
  • In order to check whether the record is showing up in the Results container, we recommend setting a break point immediately after the Get Data Operation. Check the Results container to ensure that data is being captured correctly.
