Deleting Consecutive Identical Values from DIAdem Channel
Updated Mar 6, 2018
  • DIAdem
I want to delete any consecutive, identical values from a channel in DIAdem. How can I do this?
In DIAdem 2017, there is a built-in remove duplicates function under the Analysis tab.
In older versions of DIAdem, the user will need to remove the duplicates manually or write VBScript code that implements this logic.
