Can I Output on the Serial and Ethernet Lines of a cRIO-9035 at the Same Time?
Updated Mar 15, 2018
  • cRIO-9035
  • NI-RIO
My system requirements dictate that I output on the serial port and maintain an Ethernet connection at the same time. Is this possible on a cRIO-9035?
Yes, the cRIO-9035 has two Ethernet ports, an RS-232 serial port, and an RS-485/422 serial port. You can transmit data on all of these lines independently.
