Output Different Voltage on Each Analog Output Channel in DAQmx
Updated Mar 15, 2018
  • Can I output a different voltage on each analog output channel in one DAQmx task?
  • The documentation for the number of concurrent DAQmx tasks on a CompactDAQ (cDAQ) chassis states that you can only have one analog output task per chassis. Does this mean I have to have a separate, software-time task for each different analog output voltage?
You can write different voltages to each analog output channel in the same DAQmx task. In a DAQmx task, you must ensure that each channel is the same frequency, number of samples, and type (e.g. all analog output). However, you do not have to write the same values to the analog output channel.
