Can I Use The NI SHC68-68-EPM With The PXI-6225
Updated May 21, 2018
  • SHC68-68-EPM
  • PXI-6225
The DAQ Multifunction I/O Cable and Accessory Compatibility documentation states "NI recommends that you use the SHC68-68 cable when the SCB-68 or SCB-68A is connected to Connector 1. You can not use the SHC68-68-EPM cable on these connectors and I am confused. Is it possible for me to use the NI SHC68-68-EPM With The PXI-6225?
The message in this documentation is specifically for Connector 1. The SH68-68-EPM should be used on Connector 0, and the SH68-68-S on Connector 1.
