To use the NI cRIO Profibus Module (cRIO-PB-MS) with the latest versions of LabVIEW you should install or upgrade your existing Profibus driver to the latest
cRIO-PB-MS by KUNBUS GmbH version. The driver installs Profibus Master and Slave support for LabVIEW and brings Configurator III to setup the Profibus Master module (PBMS). The latest NI cRIO PROFIBUS driver also adds support for LabVIEW Real-Time.
With cRIO-904x or 905x controllers
If your already had Configurator on your machine when updating the driver, uninstall Configurator III through Windows, and then reinstall the latest version through VI Package Manager.
If this is the first time you install Configurator you can simply run the installation of the latest driver in VI Package Manager and confirm Configurator III gets installed
