Yes, you can build the J1939 database on the XNET DB Editor. For creating a database file, follow the below steps :
1. Set the Application Protocol as J1939
2. Click on the
J1939 PGN to specify the PGN settings.
3. If user knows the PGN, he can use the
Full PGN option. Otherwise specify the PGN fields individually.
4. Enter the CAN Identifier
5. The Overall nature of the frame is graphically depicted on the side
6. Each Row of the frame specify the individual parameters
