LabWindows/CVI 2013 and later use the Clang compiler instead of the CVI compiler that is used in LabWindows/CVI 2012 and earlier. The Clang compiler in LabWindows/CVI 2013 and later reports some compiler errors as warnings that the CVI compiler reported as errors in earlier versions. Code modules with these errors will compile successfully, but may produce errors at run-time.
The following list contains code errors that produce a compiler error in LabWindows/CVI 2012 and earlier, and a compiler warning in LabWindows/CVI 2013 or later:
Passing an incompatible pointer as a parameter:
void foo (int *c)
return;
void bar (void)
char c;
foo (&c);
Extraneous return value:
void foo( )
return 0;
