- In NI Measurement & Automation Explorer (MAX), my USB-8451 appears as connected under Devices and Interfaces. However, when I try to program this device in LabVIEW, I receive error code -301713.
- My LabVIEW VI communicates with a USB-8451. Whenever I use a Property Node to read/write device properties, I receive an error stating that An input parameter, or combination of parameters, is invalid. What causes this?
- When programming my USB-845x device, I receive the below error. How can I fix this?
Error -301713 occurred at <location>
Possible reason(s):
NI-NI-845x: An input parameter, or combination of parameters, is invalid. An example of this error may be setting an invalid baud rate or enabling I2C ACK polling while using 10-bit addressing.
