LabVIEW Project Graphics Overlapping
Updated Mar 15, 2018
I recently installed LabVIEW and after creating a new project I see the tree graphics overlapping and it is hard to interact with the project.
This behavior is often solved by changing the DPI (Pixels/Dots Per Inch) settings in Windows. Navigate to your Windows Control Panel >> Appearance and Personalization >> Display and change the magnification. Simply toggling the display setting often resolves the issue.
