Can I Manually Remove a Packed Project Library from Memory in LabVIEW?
Updated Mar 15, 2018
My program uses VIs in packed project library. Can I manually unload the packed project library when I am done?
There is no way to manually unload an item from memory. The items will unload automatically as long as they are not dependencies of other items loaded in the program.
