LabVIEW Crashes When Running Large Case Structure
Updated Apr 6, 2018
I have a LabVIEW VI that contains a case structure with a very large number of cases. When I try to save this Vi LabVIEW occasionally crashes. Is there a limit to the number of cases I can have in a case structure?
No there is no hard limit to the number of cases in a case structure. If you are experiencing performance issues it is recommended to merge cases where possible, and make your code more modular by using Sub-VIs.
