Enable or Disable Front Panel Scroll Bars
Updated Apr 5, 2019
  • When I call a VI within a subpanel in another VI, I don't want the scrollbars to show up
  • How do I hide or show the front panel scroll bars?
You can remove the horizontal and vertical scroll bars manually by right clicking on the scroll and selecting Horizontal Scrollbar >> Off While Running and then doing the same for Vertical Scrollbar as shown in the image below.
 If both scroll bars are missing you can get them to reappear with the following steps:
  1. Select File»VI Properties.
  2. Select the Window Appearance category.
  3. Click Customize.
  4. Place a checkmark in the boxes for Show vertical scroll bar and Show horizontal scroll bar, as desired.
You can also show or hide the horizontal and vertical scroll bars of your SubVI panes programmatically using property nodes.
