SHC68-C68-RDIO2 vs SHC68-68-RDIO Cables for R Series Devices
Updated Sep 16, 2024
  • PXIe-7820
  • SHC68-C68-RDIO2 Cable
  • SHC68-68-RDIO Cable
Is it better to use the SHC68-C68-RDIO2 Cable or the SHC68-68-RDIO Cable for my R Series Device?
The SHC68-68-RDIO Cable is the recommended cable for connecting to the following devices:
  • cRIO-9151 R Series Expansion Chassis
  • PXI/PCI 783xR
  • PXI/PCI 781xR
  • NI 7841R / 7842R(PCIe-7841R / 7842R、PXI-7841R / 7842R)
  • NI 7851R / 7852R(PCIe-7851R / 7852R、PXI-7851R / 7852R)
  • NI 7853R / 7854R(PXI-7853R / 7854R)
The SHC68-68-RDIO Cable is not recommended for the USB R Series, PXIe-782xR, PXIe-784xR, or PXIe-785xR since the two devices are not interchangeable.
The SHC68-C68-RDIO2 Cable is the recommended cable for connecting to the DIO ports of the following devices:
  • USB R Series
  • PXIe / PCIe-782xR
  • PXIe-784xR(not include PXI-784x)
  • PXIe-785xR(not include PXI-785x)
  • PXIe-786x / 786xR
  • PCIe-7846
  • PCIe-7856 / 7857 / 7858
The SHC68-68-RDIO Cable can be used with Virtex-II / Virtex-5 FPGA R-Series devices.
The SHC68-C68-RDIO2 Cable can be used with Kintex-7 FPGA R-Series devices.
