The following High-Performance Camera Link frame grabbers support PoCL:
- PCIe-1433
- PXIe-1435
- PCIe-1473R (Please note the 1473R inherently supports PoCL and no .icd file needs to be edited to enable PoCL for this card)
The camera's PoCL compatibility should be explicitly documented in the camera's user manual provided by the vendor. In order to enable PoCL for your camera, add the following line to your camera's .icd file under the section for your frame grabber.
EnablePoCL(Yes)That will allow the frame grabber to provide power to a PoCL camera. The only exception to this implementation is the PCIe-1473R. This frame grabber has PoCL enabled by default.
