Bad_IndexRangeInvalid Error When Using OPC UA Multiple Write VI
Updated Feb 26, 2018
  • LabVIEW OPC UA Toolkit
This is issue is encountered while using the OPC UA Multiple Write VI. I am able to read the node attributes but cannot receive the values and receive status: ​
​Bad_IndexRangeInvalid
This is a known issue with OPC UA. For a work-around patch please contact National Instruments technical support.
This issue is caused by the time stamp being a required input for the Multiple Write VI. However, the VI is password protected and any edits must be made by authorised NI personnel.
