Inserting a Picture into a .NET Container
Updated Mar 9, 2018
Other
I want to insert a picture into a .NET Container which is saved on my computer.
  1. Create a .NET Container in front panel.
  2. Right click .NET Container, in select .NET control, config it as Figure 1.
Figure 1
  1. Use property node to set and control the property of .NET container, use the property node ImageLocation, write the path of the picture into this property node, the whole program is shown as Figure 2.
Figure 2. Using .NET Container to Display a Picture
