I Get "Unable to reboot the target. It may be offline or unresponsive." When I Try to Run as Startup
Updated Mar 15, 2018
  • CompactRIO Chassis
  • CompactRIO Chassis (Legacy)
  • System Configuration
I have built my Real-Time Application in my LabVIEW project. I set the specification as startup and when I click Run as startup, it prompts me for the usename and password. After entering this information and continue, I get the next error message:
This message is generic when cases where the target cannot be reached. In this specific scenario, it's very likely that you have entered your username and password incorrectly.
Try accessing the cRIO from the NI Web Configuration and verify that you are using the correct username and password.
