Client HTTP VI's Are Slow or Don't Behave as If They Are Reentrant
Updated Mar 6, 2018
I am attempting to make multiple HTTP request in parallel, but it is resulting in my VI slowing down. Shouldn't the HTTP VI's be reentrant?
Although the HTTP Client VI's are re-entrant (meaning multiple instances of the VI can run in parallel), only 1 request can be made at a time for one Client Handle. If you create multiple handles (see below) using the OpenHandle VI you will be able to successfully make HTTP requests in parallel.
