How Can I Create a VI Snippet for an Older Version of LabVIEW?
Updated May 3, 2018
I have LabVIEW 2017 installed but need to create a VI snippet for version 2015. How can I do that?
There is a Third-Party Add-On for LabVIEW that you can use to achieve this functionality: the Code Capture Tool from LAVA.
  1. After installation you find it in LabVIEW's menu located at Tools»LAVA»Code Capture Tool...:
  1. Click the Configure Snippet icon the get to the dialog allowing setting the LabVIEW version of the snippet:
  1. There you can set the desired version in the Version drop down menu:
VI snippet PNG files include metadata that allows LabVIEW to rebuild the code.
