For CLIPs to run on an external clock, a dedicated line for the clock has to be configured. For instance, we are using a simple adder which is clocked using the clk signal.1. As shown below configure the clk signal as a clock line in the signal type.2. Refer to the link CLIP Tutorial, Part 3: Adding CLIP to a Project, as mentioned in step 9, configure the external clock line in the Clock selection page.
For complete information on configuring the CLIPs and adding them to the project refer to the CLIP Tutorial. For highly detailed information on using the LabVIEW FPGA Module and its features refer to the comprehensive LabVIEW FPGA Module Help Document.
