Can I Use a SHC68-68-EP Cable in a cDAQ System?
Updated May 3, 2018
  • SHC68-68-EP
I am upgrading a system based on a PCI or PCIe DAQ card to a cDAQ system. Currently, I use a SHC68-68-EP cable to connect my DAQ card. Can I use this same cable to connect to my new cDAQ system?
No, National Instruments does not produce any C-Series modules with the proper terminal block to connect to the SHC68-68-EP cable. This cable carries 68 wires of data, which is a higher channel count than a single C-Series module can handle.
