To correct this error, you have to change the name in the Unbundle by Name node to match the name of any item in the cluster. In the case of a bad terminal, each node has different requirements for how to fix the error, which you can typically determine from the context of the terminal. In some cases, the Error list window displays additional errors that can help you to determine what to fix. To see the connections for a node, display the
Context Help window and move the cursor over the node.
