Error 363506 While SettingUp LabVIEW SSL Client
Updated Mar 1, 2018
I am setting up the client end of an HTTP application that includes SSL security configuration, and I am seeing the following error about an invalid certificate path or CA information.
What is the cause of this error?
This error indicates there is a problem with the path on the local host (client) to the CA certificate file.
This error originates with the ConfigSSL VI, and an incorrect input to the argument "CA Certificate File". This VI expects to receive a root certificate file (.CRT or .CER file), you may have pointed to a .KEY or the folder storing a root certificate.
ConfigSSL VI Help
