Unexpected Menu Redraw Behavior if Menu Open LabWindows™/CVI™
Updated May 11, 2018
  • LabWindows/CVI 2015 Full
  • LabWindows/CVI 2017 Full
If I have a menu item open when I try to delete a different menu item, the menu option persists, but cannot be interacted with.
This is a known issue and can be solved with the following workaround.
Instead of deleting a single menu item, you can delete the full menu with the following:
DiscardMenuBar(menubarHandle);
menubarHandle = LoadMenuBar(panelHandle, "User Interface Application.uir", MENU);
However, if a message popup happens immediately after this then it will cause a run-time error. As long as the Message popup does not happen after the discard and load of the menu bar then the error does not occur.
