Why I Can't Move Elements in My Cluster on the Front Panel
Updated Feb 28, 2018
When I try to select an element in my cluster on the Front Panel, LabVIEW won't let me move the element around within the cluster. How can I get the individual elements of the cluster to move around?
Modify the AutoSizing property of the cluster on the Front Panel to "None".
  1. Right click on your cluster on the Front Panel. Make sure you select the entire cluster and not an element within the cluster.
  2. Go down to AutoSizing and select "None". You should now be able to move your elements around in the cluster.
