Number of Inputs/Outputs of a Switch with a 2-Wire Topology
Updated Feb 22, 2018
  • PXI-2532B
  • PXIe-2532B
  • NI-SWITCH
I'm looking to use my switch matrix in a two-wire 16x16 configuration. Looking at the documentation, it is not clear if this means it can be configured as 16 two-wire inputs and 16 two-wire outputs, or if the inputs and outputs are one-wire and will be distributed as 8 two-wire inputs and 8 two-wire outputs.
A 2-Wire 16x16 Matrix Topology means that the card will be configured as a 16x16 matrix, where each of the 16 inputs and 16 outputs will have two terminals for positive and negative connections.
For more details, refer to Topologies and N-Wire Switching Modes in the NI-Switches Help.
