Cannot Deploy System Configuration 17.5 to My sbRIO
Updated May 3, 2018
  • sbRIO-9627
  • NI CompactRIO 17.6
  • NI CompactRIO 17.0
Other
NI System Configuration 17.0, NI System Configuration 17.5,
I installed System Configuration 17.5 to replace System Configuration 17.0 on my host machine, and when I go to deploy it to the sbRIO, I only have the option to deploy System Configuration 17.0. What is the problem?
If your CompactRIO driver is not updated to CompactRIO 17.6, you will be unable to deploy the System Configuration 17.5 to your sbRIO. Update the CompactRIO driver, and you will be able to deploy the System Configuration 17.5 to your sbRIO.
