VeriStand and LabVIEW (64-bit) Compatibility
Updated Mar 6, 2018
  • VeriStand
Is VeriStand able to integrate and run LabVIEW (64-bit) executables?
VeriStand is not capable of running LabVIEW (64-bit) executables because VeriStand is dependent upon LabVIEW Real-Time which is dependent on LabVIEW (32-bit). If you have the LabVIEW (64-bit) source code though you can build the executable within LabVIEW (32-bit) and then run your VeriStand program.
