Next Steps
Data about the UUT and Station can be accessed in the Parameters.UUT and Parameters.ModelData.StationInfo variables present in many model callbacks. In TestStand 2013 and later, the UUT and StationInfo properties contain an AdditionalData subproperty, which is an unstructured container. You can add data to this property at run-time without making any changes to the UUT and StationInfo data types.
If you are interested in modifying the report header after the execution of the PreUUT sequence callback, override the ModifyReportHeader callback in the client sequence file following steps 2 and 3 in the Solution section of this document.
