Reassigning PFI Lines for an Encoder Task on DIO Module
Updated Mar 15, 2018
  • NI-9401
I would like to use all of my counter inputs for encoder measurements on my digital input/output card. However, some of the PFI lines are assigned to the same pins by default. How do I reassign these pins?
NI Measurement and Automation Explorer:
You can change the Input Terminal A & B to the preferred line as seen in the screenshot below:
LabVIEW:
You can find an example VI in LabVIEW under Help >> Find Examples >> Hardware Input and Output >> DAQmx >> Counter Input >> Counter - Read Encoder.vi
The Input Terminals can then be set on the Front Panel, as seen in the screenshot below:
