Why Do I Get an NI 845x Driver Error When Opening a LabVIEW Project?
Updated May 29, 2026
  • NI-845x
When I try to open a LabVIEW project, I receive an error message indicating that the version of the NI‑845x driver installed on my system is newer than the version used to create the project.
I am unable to proceed normally because of this version mismatch, and I am not sure which driver version I should be using or how to resolve this compatibility issue.
This issue occurs because the LabVIEW project was originally developed using a specific (typically older) version of the NI‑845x driver, and your system currently has a different (usually newer) version installed.
LabVIEW projects and drivers are version-sensitive, and mismatches, especially with hardware drivers like NI‑845x, can lead to compatibility errors.
Follow these steps to resolve the issue:
Identify the Required Driver Version
  • Review the error message carefully.
  • The message specifies the exact NI‑845x driver version that the project expects.
Check Your Current Installed Version
  • Open NI Package Manager (NIPM).
  • Search for NI‑845x driver.
  • Note the version currently installed on your system.
Compare Compatibility
Use the official NI compatibility chart:
  • Verify which NI‑845x versions are supported by your installed version of LabVIEW or LabWindows/CVI.
Confirm whether:
Your current driver is supported, or you must install the required version for compatibility.
Install the Correct Version
If your installed version does not match the required version:
Option A: Install the Required (Older) Version
  • Open NI Package Manager.
  • Locate the required NI‑845x version.
  • Install it
Note: Some NI driver versions cannot coexist, requiring a full uninstall before installing another version.
Option B: Upgrade the Project (if possible)
If you want to keep your current driver:
  • Open the project in LabVIEW.
  • Allow LabVIEW to update dependencies to newer versions.
  • Test thoroughly to ensure functionality is preserved.
Please refer to the following article: Upgrade VI to a Newer LabVIEW™ Version - NI
Best Practices
  • Maintain consistency between development environments when sharing projects.
  • Document driver versions used in projects.
  • Avoid automatic upgrades of hardware drivers in controlled environments.
