Calling Visual Basic Code from TestStand
Updated Mar 15, 2018
  • TestStand
Programming Language
  • Visual Basic .NET
I'm currently using a Test Executive software which calls VB6 and VB .NET functions.  I'd like to migrate to TestStand, how can I use my VB code with TestStand?
With TestStand 4.2 and newer, TestStand natively supports calling VB .NET assemblies using the .NET adapter.  Code in VB6 is not natively supported by an adapter, so it will be necessary to migrate code to VB .NET or create a .NET wrapper for the functions so that it can be used in a .NET assembly.
