The following cDAQ Controllers are available as a Windows Embedded Standard 7 (WES7) or a LabVIEW Real-Time system
- Four-slot cDAQ controllers (cDAQ-9132, cDAQ-9134, and cDAQ-9136)
- Eight-slot cDAQ controllers (cDAQ-9133, cDAQ-9135, and cDAQ-9137)
You can connect to WES7 systems using a remote desktop program.
Note: Although you can install the LabVIEW development environment on a cDAQ controller, it is recommended to use the development environment on a separate development computer and then deploy your code to the cDAQ controller due to storage capacity and speed.
Also, if your controller has NI Linux RT on it, and it does not appear in NI MAX, please refer to page 1-9 through 1-15 of the User Manual for cDAQ Controllers. If you are having trouble finding your cRIO or another remote target, please see
NI Networked Device Doesn't Show Up or is Missing in MAX.
Finally, if you are not sure if you have a Windows device or Real-Time device, check the serial number of the controller and compare it to our website. The part numbers are unique to the operating system we ship on it.
