"LabVIEW Must Be Installed" Message When Installing DSC Module
Updated Sep 20, 2018
Even though I already have LabVIEW installed, my installation of the Datalogging and Supervisory Control (DSC) Module is interrupted by an error message saying that I must install LabVIEW. How can I solve this issue?
The Datalogging and Supervisory Control (DSC) Module requires LabVIEW 32 bit. If you have LabVIEW 64 bit, the DSC installation will not detect LabVIEW and generate your error message. Hence, make sure you have LabVIEW 32 bit installed.
