Is There a cDAQ Module I Can Use To Communicate With The Tektronix PA1000 Analyzer
Updated Mar 20, 2018
  • cDAQ-9174
I have a Tektronix PA1000 Analyzer that I want to integrate into an existing cDAQ system. Is there a module I can use to accomplish this?
According to the Tektronix PA1000 Analyzer hardware configuration it requires a GPIB, USB or Network connection to communicate. This connection will not be able to be made with a cDAQ module and will need to be connected through the computer you are using or connected to the same network.
