Disable All Alarms in VeriStand from Target
Updated Apr 2, 2018
  • VeriStand
I would like to disable all of my alarms at once in VeriStand. I need to be able to do this from the target without having the host disable them for me so that my target can run headlessly. What is the best way to do that?
To do this, you'll need to create a procedure that disables each alarm individually. To automate this process, you can programmatically create a procedure in your system definition from the host.
To get started with programmatically creating your procedure, take a look at the following VI:
C:\Program Files (x86)\National Instruments\<LabVIEW Version>\examples\NI Veristand\API\System Definition API\Create a SDF File with Procedure.vi
The community posts linked give more specific examples of this.
