Please reference the command line arguments below.
Argument | Description | Example |
/nivsprj | Specifies the UI Manager project to run. | /nivsprj "<Common Data>\Examples\Stimulus Profile\Engine Demo\Engine Demo.nivsprj" |
/sysdef | Specifies the system definition file to use. | /sysdef "<Common Data>\Examples\Stimulus Profile\Engine Demo\Engine Demo.nivssdf" |
/gateway | Specifies the IP address of the VeriStand Gateway. | /gateway 10.0.38.64 |
/connect | Tells UI Manager to connect to the target defined by the system definition file. | /connect |
These arguments can be found in the
Stimulus Profile Help, and you can use these from the Stimulus Profile Editor, LabVIEW using System Exec., or any other application that can access command line.
When using these commands, make sure that you target
NationalInstruments.VeriStand.UIManager.Application.exe located in
C:\Program Files\National Instruments\[your version of NI VeriStand UI Manager].
