Can C Series Devices Be Used on a Linux Machine?
Updated Jun 20, 2018
  • CompactDAQ Chassis
  • C Series Voltage Input Module
  • C Series Voltage Output Module
  • USB-9211
  • USB-9215
  • USB-9233
  • USB-9234
  • NI-DAQmx Base
  • Linux
I have a CompactDAQ (cDAQ) chassis and want to be able to use it on a Linux machine. Is this possible, and if so what driver do I need to install?
NI-DAQmx Base is the driver required to communicate with USB DAQ hardware on a Linux machine. This driver does not support C Series chassis, but does support specific modules found within USB sleeves.  The following products are supported on NI-DAQmx Base:
  • USB-9211A
  • USB-9215A
  • USB-9233
  • USB-9234
