Global Channels Being Read in Alphabetically Instead of How They Appear in MAX
Updated Mar 15, 2018
When I read in the global channels from NI MAX they are appearing in alphabetical order. In the past I believe they were in a different order. Is there a way to change  this order in NI MAX?
Unfortunately this is a default in NI MAX and there is no easy way to change this. As a workaround you can add a letter in front of the Global Channel in NI MAX to force them into the order you need.
