LabVIEW Freezes During Launch After Disconnecting From NI VLM Server
Updated May 3, 2018
  • Volume License Manager
Programming Language
  • LabVIEW G
I was using NI Volume License Manager (VLM) based software licensing method so far. The NI VLM server computer is not connected to my development computer any more. Hence, I am using disconnected licensing method. When I launch my LabVIEW it hangs while trying to load. How can I fix this?
The hang may be as a result of loading/contacting the NI VLM server. Because, the client/development computer is configured to query the old VLM server for licenses.
Refer to the following steps to remove the old servers.ini file on NI license manager 3.9 or older:
1. Go to Start » All Programs » National Instruments » National Instruments License Manager on the Client/Development computer.
2. Remove the server list in Options » Preferences as shown below.
Refer to the following steps to remove the old servers.ini file on NI license manager 4.0 or later:
2. Remove the server list in Options » Manage Volume License Servers as shown below.
You can also automate remove/modify process as this information is stored at <ProgramData>\National Instruments\License Manager\Data\servers.ini for Windows Vista and later.
For the previous versions of Windows versions you can modify windows registry keys: HKEY_LOCAL_MACHINE\SOFTWARE\FLEXlm License Manager\NILM_LICENSE_FILE.
