Sound And Vibration VIs Are Not Executable
Updated May 3, 2018
  • Sound and Vibration Toolkit
I have a LabVIEW application that calls VIs from the Sound & Vibration Measurement Suite and I have a Broken Arrow. When I click the arrow, I get a message saying "SubVI is not executable".
If I enter the subVI, the arrow stills broke, but the error message changes. Now it says, the VI is not proper licensed.
If you have an application that was built using VIs from the Sound & Vibration Measurement Suite and you only have access to the Sound & Vibration Toolkit. You will be able to see the VIs  from the suite correctly, but they will result on not executable VIs. This because you don't have access to the piece of software that contains the VIs.
To get access to those VIs, you will need to activate the Sound & Vibration Measurement Suite.
See Related Links section for more information.
The Sound & Vibration Measurement Suite and the toolkit come on the same installer.
