How to Apply Changes to All Instances of a Custom Type
Updated Sep 28, 2018
  • TestStand
I created a *.seq file and have many instances of customer steps and data types, which I want to
modify all at once rather than one at a time.
If you need to modify all instances of a custom data type:
1. Open the *.seq file with the data types you want to modify
2. Open the types palette
3. Find the custom data type in MyTypes.ini.
4. Right click the property of the custom data type which you want to modify and select properties from the content menu that appears.
5. Modify the value entry.
6. Check the Apply Value to All Loaded Instances of the Type box
7. Click OK
If you need to modify all instances of a custom step:
5. Modify the values from the step's Properties dialog box.
6. Check the Apply Changes in this Dialog to All Loaded Steps this Type box.
7. Click OK
